traditional ni-daq windows 7
Hi team
I am new to LabVIEW.i want know about how to crate traditional NI-DAQ(Lagacy)devices in NI max. Now I am using windows 7 PC. pls ref attachment for reference
thanks and regards
Mohan
Message 1 of 8
(4,652 Views)
Download here and install the Traditional NI-DAQ drivers.
They will only work under Windows 7 32 bit.
I'm not sure they can really co-exist with NI-DAQmx drivers like in your picture.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 2 of 8
(4,639 Views)
Hi Mohan,
please read this and that!
Why do you insist on using the TraditionalDAQ driver?
Btw. BMP images are banned because of their filesize. Why don't you save your screenshots as PNG files? (See attachment.)
Message 3 of 8
(4,638 Views)
Hi GerdW
             The code already made by using Traditional DAQ driver. Now I am using window XP PC.I am going to change my pc in windows 7.
Message 4 of 8
(4,627 Views)
Hi GerdW
Thanks and regards
Mohan M
Message 5 of 8
(4,625 Views)
Hi Mohan,
you need to install the TradDAQ driver as already suggested in the messages above!
So you want to replace a PC with outdated OS and outdated hardware driver by a PC with nearly outdated OS and still outdated hardware drivers?
That's what I call "future-proof" development… 😄
Message 6 of 8
(4,608 Views)
maintenanace wrote: The code already made by using Traditional DAQ driver. Now I am using window XP PC.I am going to change my pc in windows 7.
This sounds like a good time to update the code to use DAQmx instead of Traditional DAQ.  It will be a really good learning experience.
Message 7 of 8
(4,564 Views)
Oh yes this.  DAQmx is so much easier to work with.  But even if it was harder, you aren't going to get much support from NI for T-DAQ stuff.  So if something doesn't quite work right, and you are using traditional DAQ on an operating system it wasn't designed, or tested for, then NI might not be able to help you with it anyway.
Message 8 of 8
(4,541 Views)
