NImodbus
"Timed loops internally call a dll (lvalarms.dll).  Make sure you have this.  "
What I meant was, Timed loops actually calls loadlvalarms.vi which, in turn, calls the above dll.
-Khalid
Message 11 of 15
(1,697 Views)
@Khalid wrote:
Timed loops internally call a dll (lvalarms.dll).  Make sure you have this.  ...
Khalid,
I think timed loops were introduced in LV7.1, and rogue is using LV7.0  ... so his/her problem is somewhere else.
Fading out. " ... J. Arthur Rank on gong."
Message 12 of 15
(1,691 Views)
You're probably right -- I am not sure of the release-timing of the Timed loop  Smiley Tongue
The solution is to replace it with a While Loop.  I would do that even if it's 7.1 or beyond, unless I am really doing some time-critical stuff.  Just make sure that there's a Wait function added to the While Loop with the value from the Period input of the Timed Loop.
-Khalid
Message 13 of 15
(1,684 Views)
Hello evey body
this is a  screen shot of the diagram on my computer, as you see, the timed loop is broken, Smiley Sad , I can't resolve the problem!!! it doesn't work with a while loop neither with a timer!!!! and there are any error message beacause my computer was blocked each time
Message 14 of 15
(1,669 Views)
Hi rogue,
Try to do it like this 😉
Message Edité par TiTou le 03-29-200608:22 AM
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
Message 15 of 15
(1,663 Views)
