NXG Style Tab Control
I've noticed a weird issue with the NXG Style Tab Control and wanted to see if anyone else has run into this (using LabVIEW 2018). I have multiple tabs that I programmatically set visibility using the PageVisible property. What I noticed is that during runtime, if I hide tabs, the front panel still shows part of the outline (see vertical lines below). When I replace the NXG Style Tab Control with a System Tab Control, the issue disappears. Not sure if this is a bug or not, but anyone else see this behavior?
(3,740 Views)
Just wondering, if you minimize and un-minimize the front panel will the lines go away?
(3,719 Views)
The lines disappear if minimize then maximize the screen. Tried it on two PCs with same results.
(3,691 Views)
