Unbundled class value different to actual class value
Hope someone can help with what looks like an obscure issue. I have a class called 'mcp2210', and one of the private data values is called "Handle".  When I create the class, the "Handle" value is created and stored with the class. Everything looks fine up to this point. However, when I then try to access the "Handle" value, the unbundled value is different to the stored value. Putting probes on the class wire and the unbundled value, I can clearly see that the class wire holds the correct "Handle" value, but the unbundled value always reads as 256d.
Some other points of info:
1. Before I run this test VI, I can edit the block diagram. However, after I run the test VI just once, the cursor changes to the 'hand' symbol, and I can't edit it anymore.
2. On one occasion, for no obvious reason, the test VI ran fine, i.e. the unbundled value was correct. The it reverted back to the non-working state.
3. This code is part of a library which has been running fine for 12 months. However, I had to do a rebuild of the library to fix something else unrelated to this issue, and the fix got a bit complicated, requiring lots of mass compiles to get right. This issue has only surfaced in the new library.
4. LabVIEW version is 2016 32-bit.
(3,562 Views)
Accepted by topic author DMurrayIRL
Impossible to debug a picture.
One thing ti try is clearing out your class mutation history.
(3,546 Views)
Could you have more than 1 data field called "Handle" with one of them defined as U8 datatype? I don't know how many times things like that have driven me mad for days only to find out I was writing and reading different data fields with the same name (but different places in the hierarchy of classes).
(3,539 Views)
Hi, just to understand , is this VI reentrant or not?
https://images.youracclaim.com/size/110x110/images/7c5d31f5-2069-4618-ba59-b710c2b6bbe4/CLD.png
(3,535 Views)
Clearing the class mutation history seems to have fixed the issue. Thanks for the help!
(3,532 Views)
In order of my thoughts before I read any of the other responses:
1. Do you have multiple items in your class called "Handle"?
2. Clear the mutation history.
3. Clear the object cache (Tools->Advanced->Clear Compiled Object Cache) and then recompile.
(3,529 Views)
