NXG UI. Can we have a Tool Strip Menu in LabVIEW?
Hi there,
I'm a C# developer- new to NXG, usually I interface with NI-USB-6216 in my .NET programs.
I'm trying to port my .NET program to NXG and I'm having trouble figuring out the UI side of the NXG.
Is it possible to have a Tool Strip Menu similar to the one offered in MS Visual Studio?
Take a look at the attached screenshot to see exactly what I mean.
(2,470 Views)
I haven't used it yet myself in NXG, but you can add and edit a Menu to a gvi via the Panel tab on the configuration pane:
(2,402 Views)
Thanks, I haven't spotted it before.
I played around with it just there, and it's not that easy to use, but thanks for pointing me to the right direction.
When I type-in "menu" in the Search, there's a project called "Customizing the Menubar" and he has a nice thing going on there, now just to figure it out as a newbie 😄
(2,354 Views)
I've tried and tried to like NXG, but the incomplete feeling plus the intentional design choices have made me abandon it for now.  😞
Bill
CLD
(Mid-Level minion.)
(2,343 Views)
Ha! I never had any prior experience with LabVIEW before NXG so I'm golden 😄
As a matter of fact I've never had any experience with "visual" programming, I've always been a text based coder.
Unfortunately, a decision has been made, at management level, and now we have to move to LabVIEW.
I'm trying to wrap my head around it at the moment, and the company will be doing the training soon, but so far I'm not liking it! Haha.
Hopefully I'll change my mind as I learn.
(2,335 Views)
I came from text-based too, back in 1997 (Whoa, seeing that in writing I start feeling old.. 😱)..
Took me two weeks of cursing and 🙄, then reading up on some course work about statemachines and message handling lead me to see the light and start over. From then on I was hooked and never looked back.
For serious work though I'd recommend to start using LabVIEW instead of NXG because NXG is not quite there yet feature-wise.
(2,330 Views)
There are some paradigms that can be hard to embrace, as the dataflow and 'the wire is the variable' makes for quite a difference when moving from a text based language. If I'm trying to make a text based comparison it'd be like going from an ultra typed language like Assembler to Python, or from C to Lisp. However, most all structure and logic is the same, so once you know to loop and handle arrays it'll get better. 🙂
Qestit Systems
Certified-LabVIEW-Developer
(2,324 Views)
