NXG X Scale
The property node for a chart has x scale as a read only and there is no offset multiplier for the x-axis.  How can I customize the x-axis of a chart in LabVIEW NXG?
(3,149 Views)
Hi Danny,
You probably did not see that XScale is a reference, which is indeed read-only. Just do this:
(3,115 Views)
I'm still looking for a way to mimic the multiplier property node from regular LabVIEW to modify the numbers on the x-axis
(3,100 Views)
