NaN remover and interpolator
I have an 1D array of numbers but there are also NaN's in it, does
anyone knows how to remove them and fill em in with interpolated
numbers:
So i have for example this:
5.67
NaN
3.46
2.56
4.68
NaN
NaN
3.21
1.04
And i want it to be this:
5.67
4.56
3.45
2.56
4.68
4.19
3.70
3.21
1.04
It a linear interpolation, If there is one NaN space: first value +
third value / 2 fill in.
Where the two NaN's are i do the following: (4.68 - 3.21)/ 3 = 0.49 ->
4.68 - 0.49 = 4.19 (first filled up NaN value) then 4.19 - 0.49 = 3.70
(second filled up NaN value) but now in LabView?!
Anyone?!
Best regards Thijs
(2,989 Views)
no problem,
you can use function "in range".
I'll send an example to you.
Mike
Thijs Boeree wrote:
> Hi,
> numbers:
> 5.67
> NaN
> 3.46
> 2.56
> 4.68
> NaN
> NaN
> 3.21
> 1.04
> 5.67
> 4.56
> 3.45
> 2.56
> 4.68
> 4.19
> 3.70
> 3.21
> 1.04
> Anyone?!
> Best regards
Thijs
(2,989 Views)
Hi Thijs
You could test each number in the array with the "Not a
Number/Path/Refnum?" function in the comparison palette. Then, if you
find a NaN value, if you stored the previous value in a shift register,
keep that value. Check for any subsequent NaN's (and count how many)
until you find another non-NaN, and then do your maths to fill in the
appropriate array values (carry the array on another shift register).
Paul
Thijs Boeree wrote:
> Hi,
> numbers:
> 5.67
> NaN
> 3.46
> 2.56
> 4.68
> NaN
> NaN
> 3.21
> 1.04
> 5.67
> 4.56
> 3.45
> 2.56
> 4.68
> 4.19
> 3.70
3.21
> 1.04
> Anyone?!
> Best regards Thijs
Research Assistant
School of Physiotherapy, Curtin University of Technology
Selby Street, Shenton Park, Western Australia, Australia. 6008
email: P.C.Davey@curtin.edu.au
Tel. +61 8 9266 4657 Fax. +61 8 9266 3699
"Everyone who calls on the name of the Lord will be saved." Romans 10:12
"For all have sinned and fall short of the glory of God, and are
justified freely by his grace through the redemption that came by Christ
Jesus." Romans 3:23-4
(2,989 Views)
