Naming Timed Loops in Re-entrant VIs
i will tty again tomorrow and see if the issue is still present in 2011.
michael
Message 11 of 15
(949 Views)
Am not in a position to test enything now so please do one more test. Run the timed loop at 1ms and keep a sub vi inside which takes 2ms and create different instance and run it. If this is also working without any issue then I don't have any problem in using that in clone.
Message 12 of 15
(949 Views)
I was curious enough to tempt fate:
There are both clones spinning nicely without issue in 2011
Message 13 of 15
(947 Views)
Why is this useful?  Are you thinking the subVI should be reentrant, or not?  I changed my test code so the loop runs at 1ms with a 2ms wait inside, no problems:
Note the L954013 at the top left of the timed loop - that's the loop name about which the question was originally asked.
Message 14 of 15
(940 Views)
From the answers shown here it appears as if the Structure Name is not required for the simple use of a timed loop in a re-entrant VI - thanks for your help.
Message 15 of 15
(923 Views)
