04-12-2012 01:37 PM
i will tty again tomorrow and see if the issue is still present in 2011.
michael
04-12-2012 01:37 PM
04-12-2012 01:42 PM
I was curious enough to tempt fate:
There are both clones spinning nicely without issue in 2011
04-12-2012 02:09 PM
@P Anand wrote:
Am not in a position to test enything now so please do one more test. Run the timed loop at 1ms and keep a sub vi inside which takes 2ms and create different instance and run it. If this is also working without any issue then I don't have any problem in using that in clone.
Why is this useful? Are you thinking the subVI should be reentrant, or not? I changed my test code so the loop runs at 1ms with a 2ms wait inside, no problems:
Note the L954013 at the top left of the timed loop - that's the loop name about which the question was originally asked.
04-12-2012 03:31 PM
From the answers shown here it appears as if the Structure Name is not required for the simple use of a timed loop in a re-entrant VI - thanks for your help.
