Nasty LV Quirk
The property node does not disappear if the TypeDef is first promoted to Strict, then downgraded to Control.
Of course, the container vi must be in memory and changes must be applied for each modification.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 11 of 15
(742 Views)
@billko wrote:
How about finding each instance and disconnecting it?  Then, only after all the typedefs have been disconnected, make the typdef a control?
If all instances are disconnected, you might as well delete the type def...
Message 12 of 15
(734 Views)
I've hit a bump in the road with my scripting: In addition to disconnecting the boolean controls, I want to disconnect any linked boolean constants; but I can't figure out how to get the typedef path from a boolean constant.
Message 13 of 15
(711 Views)
Use the type def path property?
Or get the constant Terminal value (variant), and use variant tools to get the type def path:
Message 14 of 15
(708 Views)
Well, he did say he wanted to keep the control as a control.  The whole point was to make it a control without making all the property nodes go away.
Bill
CLD
(Mid-Level minion.)
Message 15 of 15
(701 Views)
