Need Help to memorize array
Hi ,
I have a for loop , It consists of array of complex number , My query is how to memorize the array in previous iteration?
Message 1 of 10
(2,716 Views)
@happymood wrote:
Hi ,
Have you tried something to achieve this?
Have you aware of shift registers? which will store previous iteration values.
To suggest specifically need better explanation on your query.
Message 2 of 10
(2,714 Views)
Thanks for replying,Here is pic  I want the data from usrp to be remembered in previous loop of iteration.
Message 3 of 10
(2,679 Views)
Accepted by happymood
As suggested already have you tried  shift register to hold the previous iteration values, By Extending the Shift register you can access More than 1 iteration value as well.
Shift Registers: Passing Values between Loop Iterations - NI
Note: We cannot debug picture, always good to share the code snippet/VI
Message 4 of 10
(2,665 Views)
Message 5 of 10
(2,661 Views)
@happymood wrote:
HERE IS VI
Still, I am not getting response for my question, have you tried shift register?
I also shared link to how to use shift register.
Message 6 of 10
(2,658 Views)
Thanks sir got it from documentation
Message 7 of 10
(2,641 Views)
Sir can you bit explain regarding extract frame vi. I only had pic from a videoEXTRACT FRAME.jpg
Message 8 of 10
(2,637 Views)
Shift register. Drag the wire to the loop border and r-click -> Replace with shift register.
Qestit Systems
Certified-LabVIEW-Developer
Message 9 of 10
(2,627 Views)
Attached Picture is not clear enough to understand what that VI is, I assume it can be of any UserLib Files/Project files/Instrument Library Files. Without knowing we cannot let you know on what it is...
Message 10 of 10
(2,618 Views)
