Need Help to memorize array
Hi ,
I have a for loop , It consists of array of complex number , My query is how to memorize the array in previous iteration?
Message 1 of 10
(2,666 Views)
@happymood wrote:
Hi ,
Have you tried something to achieve this?
Have you aware of shift registers? which will store previous iteration values.
To suggest specifically need better explanation on your query.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 2 of 10
(2,664 Views)
Thanks for replying,Here is pic  I want the data from usrp to be remembered in previous loop of iteration.
Message 3 of 10
(2,629 Views)
Accepted by topic author happymood
As suggested already have you tried  shift register to hold the previous iteration values, By Extending the Shift register you can access More than 1 iteration value as well.
Shift Registers: Passing Values between Loop Iterations - NI
Note: We cannot debug picture, always good to share the code snippet/VI
Message 4 of 10
(2,615 Views)
Message 5 of 10
(2,611 Views)
@happymood wrote:
HERE IS VI
Still, I am not getting response for my question, have you tried shift register?
I also shared link to how to use shift register.
Message 6 of 10
(2,608 Views)
Thanks sir got it from documentation
Message 7 of 10
(2,591 Views)
Sir can you bit explain regarding extract frame vi. I only had pic from a videoEXTRACT FRAME.jpg
Message 8 of 10
(2,587 Views)
Shift register. Drag the wire to the loop border and r-click -> Replace with shift register.
Qestit Systems
Certified-LabVIEW-Developer
Message 9 of 10
(2,577 Views)
Attached Picture is not clear enough to understand what that VI is, I assume it can be of any UserLib Files/Project files/Instrument Library Files. Without knowing we cannot let you know on what it is...
Message 10 of 10
(2,568 Views)
