Need Help with Loops
Hello all,
I am a beginner in Labview. So need help in Loops. Please check it out the attached vi and suggest me the procedure which i followed is efficient or not. If not correct me.
Waiting for reply
Silver_Shaper | CLD
Message 1 of 12
(5,406 Views)
Have you ever wondered what would happen if you would replace the "equal TRUE" with a plain wire? 😮
Message 2 of 12
(5,402 Views)
For arrays, use the primitives to convert the booleans to (0,1)s then sum the array. I've modified your first loop to what I've described in the attached snapshot, you can do this for all your loops:
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 3 of 12
(5,400 Views)
altenback - you could always use the function depicted in my icon instead Smiley Very Happy
Message 4 of 12
(5,395 Views)
Thronic You Rocks.... Thanks for the fast reply
Silver_Shaper | CLD
Message 5 of 12
(5,392 Views)
Silver_Shaper | CLD
Message 6 of 12
(5,392 Views)
Not so fast. Except for the first loop, a simple "or array elements" would be all you need. 😉
Message 7 of 12
(5,387 Views)
Accepted by Silver_Shaper
According to the diagram comment, the array sizes are all 16, so here's all you need: 😄
(Hmm, the snipped clips the booleans in the diagram constant, just ignore that)
"AND array elements" checks if all a true (top wire)
"OR array elements" checks if at least one is true. (all others)
Message 8 of 12
(5,379 Views)
Please check it out.
Silver_Shaper | CLD
Message 9 of 12
(5,363 Views)
  • Again, for each little case structure that adds 1 to the value, replace the case structure with an Add primitive, convert each conditional boolean to a (0,1) and wire it to the second terminal of the Add.
  • Move your "Shift Reg Input" and "Shift Reg Output" terminals outside the error case structure, wiring them directly for the error case, to ensure the data is not lost in the event of an error at the error in terminal
Message 10 of 12
(5,351 Views)
