Need Help with reading a .CSV file and using data from file to output
Ok thank you. Sorry, I just began learning labview a couple days ago. Now the code seems to be working besides the output given is zero. I made the current values default now like you said. Ill attach the CSV file along with it.
Message 11 of 12
(1,015 Views)
Accepted by topic author sportsguy99
It works for me!
If I enter FGFDH,  I get an array that consists of 0, 43, 354.  The first element that is a 0 is from the conversion of the serial number to a number, which is of course meaningless.  You can ignore it, or do an Array Subset either before or after the conversion to essentially delete.  (Or Delete from Array).
Message 12 of 12
(1,013 Views)
