Need Script to Create Event Registration Refnum Control
Given a typedef, I want a script to create a control that's an event registration refnum control for a user event of that data type.
I've tried the "New VI Object" function, but I can't figure out what "style" to use:
I could do it by manipulating a scratchpad VI, but there ought to be a cleaner solution.
(2,477 Views)
Accepted by paul_cardinale
Start off with a scratch control that contains a user event reference of any type. Then drop your cluster typedef on the panel of the scratch panel. Then use the Move method to move the cluster control into the user event reference to set its type.
This is the only way to accomplish the task that I know of. Well, other than scripting the diagram you showed above and doing 'Create Indicator' on the Create User Event function...
(2,447 Views)
 paul_cardinale,
You marked this issue as solved. Could you post a screenshot of the solution, please?
Thanks!
(2,231 Views)
@null_and_void wrote:
 paul_cardinale,
Thanks!
Sorry.  I don't remember which project that was, much less which VI.
Just follow Darren's instructions.
(2,223 Views)
