Need Speedup
@altenbach wrote:
wiebe@CARYA wrote:
@altenbach wrote:
wiebe@CARYA wrote:
@paul_cardinale wrote:
As a side note: Starting with LV 2021, the Concatenating tunnel mode works with strings.
WHY O WHY don't they tell us stuff like that??
I assumed that, because the down-converted code was broken and a concatenating string tunnel would have fixed it. 😄
(apparently, they did not bother implementing a down-conversion substitution, e.g. as with the IPE, for example)
I suppose concatenating the string in the tunnel is faster? I'd guess building an array and concatenating that takes an extra step.
My (wild) guess is that the compiler will probably create nearly identical machine code after all optimization. 😄
There's a good change it will, but only if debugging is off. With debugging on, I think it will be harder to optimize..
Message 21 of 21
(336 Views)
