Need assistant in few concepts of like implementing FIFO and comparing it and regarding front panel
Hello
What attached VI is doing getting the byte from the serial and converting to Hex and then storing to the file. it should look like:
53
00
01
FF
00
FF
00
FF
00
What i am trting to do is to make a FIFO and compare it with the other having the required termination condition... getting problem in implementation not getting a right path to do it..
trying to make a condition to look for End of data pattern in coming data like "FF00FF00FF00" when every I receive this continues data loop should terminate. Sending you vi also with details marked in it...
waiting for your reply..
(3,138 Views)
Hi Ali,
a FIFO can be realized in LabView by using a shift register with an array of data - see attachment!
(3,118 Views)
 Thanks Sir appreciate your help. Problem solved, will integrate with my code at my test lab and will give you confirmation
(3,105 Views)
Hello GerdW have one query I am tiring to write the pattern in file just like in my original query but don't want to write the matched pattern in file mean termination condition should be not write can u help me on this I am struck.
(3,071 Views)
Hi Ali,
one way would be to replace all termination chars by nothing (aka "empty string") - see attachment.
(3,055 Views)
Thanks for your help till now, but want to clear few things so you can guide me to finish this problem
But I want to write the values in text file but for that I have to convert the string to hex because other wise non printable char will be not written and should be write as
53
00
01
02
03
04
05
now I need help to convert the data which is existing FIFO to Hex and written in file only when pattern is not match like  ( the blue values should be added in file)
FIFO start:
53
5300
530001
53000102
5300010203
530001020304
000102030405    53  ( file should start writing from here)
0102030405FF   00
02030405FF00    01
030405FF00FF    02
0405FF00FF00    03
05FF00FF00FF    04
FF00FF00FF00    05
GerdW  I hope now I have tried to clear the picture.
(3,033 Views)
Accepted by topic author Ali Afzal
Hi Ali,
see attachment: creating of hex formatted string from your input without inclusion of termination chars...
(3,022 Views)
