09-14-2011 04:07 PM
I have a really old ap written by a long gone developer, that has sections written in LabView 7.1. We have a license for 7.1 but can't locate disks anymore. Several of the 7.1 VI's will not load and convert into LV10.1 so I need to look inside and see what they are doing, then rewrite into LV10.1.
09-14-2011 05:00 PM
What's the error you get when you attempt to convert them to a more recent version of LabVIEW? Most likely the reason you can't convert them is that the block diagram has been removed, and unfortunately, if that's true, then having a copy of 7.1 available won't help - you still won't be able to look at the (non-existent) block diagram.
09-14-2011 07:29 PM - edited 09-14-2011 07:29 PM
Contact your NI app Engineer for your area. They should be able to get you the older version for your Win 98 or prior system.
