Need driver for KVH DSP-3000
I badly need a VISA or RS232 driver for KVH company's DCP-3000 optical gyro.
We have the 1000Hz asynchronous version (a driver for the 100Hz version will also work.
Roy
(3,889 Views)
Hi Roy,
Unfortunately, we don't have a driver for your instrument. Hopefully, someone here has one and can help you out. Have you tried contacting the manufacturer to see if they have anything? Good luck! Thanks!
Ebele O.
(3,873 Views)
Roy
Here is the manual http://www.kvh.com/pdf/540215B_web.pdf (628 Kb)
You could "roll you own" using the information in Section 3.
David
Edit: For PDF file size.
Message Edited by David Crawford on 09-18-2006 02:41 PM
(3,866 Views)
I'm in the same position.. KVH gave me a simple .exe  file to read from the gyro.. but would not
supply the source code (Vi)  for it...
(3,314 Views)
Roy... did you ever get something that works ?
(3,252 Views)
lastcall,
We ended up 'rolling our own'.  I will tell you it was NOT a trivial effort.  I will review the code and contact my boss to see what I will be allowed to share.
Roy
(3,243 Views)
Thanks..  I've been at it for awhile now myself... I totaly understand the non trival part of it....
Thanks again..
(3,237 Views)
