Uninstall software
Hello guys,
I want to make an application which will install say Labview run time engine while running on PC which does not have Labview installed (I know how to do this). And after closing the exe it should uninstall it (Don't know...Smiley Sad). Is it possible?
This application is like a Demo for client...
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(2,862 Views)
You can do this by executing a command line.  Something like this:
msiexec /quiet /uninstall lv82runtime.msi
http://www.medicollector.com
(2,814 Views)
