Need guidance for working with the available example labview VI
I'm working with the pulse signals and the pulse signals will be effected by the motion artifacts.There is similar thread available on labview here  Adaptive filtering to cancel out noise from an pulse signal  for removing the motion artifacts from pulse signals.so,I am planning to use the vi posted in the thread as LMS block by block(example) with sampling rate of 100Hz and number of samples needed=100 using DAQPad-6015/6016.
But I am confused with the channels of DAQ as the author(who bulit this vi) says the channel0 for signal and channel1 for reference signal as shown  in the attached image.
1)If channel1(aio) of DAQ is feeded with the analog input of pulse signals then what is the input needed/feeded to the channle1 of DAQ.
2)Can I directly use the vi by changing the sampling rate of 100hz and number of samples=100 or anything else is needed for this requirement.
Can someone explain me the required input to the channels and settings with the DAQ. thanks.
(2,766 Views)
can someone explain how the DAQ channels settings are to be done.
thanks.
(2,711 Views)
