is it possible to generate only-high or only-low state with counter?
Hi all,
  I have one digital line connected to an external switch. I am sending a TTL high or low to switch the device on or off. But for some reason, I need to consider the synchronized issue so I have to switch the device on for some times and turn it off, which was done by using a counter instead. I set the counter to use external clock to drive the counter to output 1 TTL pulse. Now come to the question. To use counter, I must output a pulse (HIGH and LOW). But sometimes I need to output only HIGH state or only LOW state. Is it possible to implement that with counter line?
(2,817 Views)
Can you explain more about why you need to use a counter? There are ways to synchronize digital outputs, so maybe you could still use this option.
(2,766 Views)
You can clear the counter task and create a new digital output task on the same line.
(2,753 Views)
No need to clear the counter task, just unreserve it!
(2,746 Views)
