Need help finding the FP Get Configuration Info.vi in Labview 8.5
I have had a problem with a program that I have put together to run a fieldpoint system. The program works fine on the development computer but as soon as I install it on a client pc i have problems with the program not linking to the .iak file. I have contacted NI and an engineer has said to me that I should include a ' FP Get Configuration Info.vi ' at the begining of my program and that should solve the problem. I am using Labview 8.5 and am unable to find the vi. Can anyone help and tell me where I can find the vi. Thanks
(2,719 Views)
That's strange. I can see it in LabVIEW 8.6 but not 8.5. You should probably contact the engineer and he/she should be able to advise further. Be sure to post back if you do go that route and get an answer.
Message Edited by Adnan Z on 01-05-2009 07:01 PM
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,715 Views)
Don't have 8.5 loaded right now.  Shows up in LV8.2 & LV8.6 on palettes under Measurment I/O>Fieldpoint>Advanced.  I'll assume that you have used the search function on the Functions palette.
Have attached copy of LV8.2 vi for you to try.
Message Edited by centerbolt on 01-05-2009 10:17 AM
(2,707 Views)
