Need help in PID
Hello ,
I am Trying to implement PID loop but facing some issues.
Input :- Feedback from motor in terms of PWM fixed duty cycle and varying frequency .
Output :-  is fixed frequency and varying duty cycle .
Observation is irrespective of set point motor is running in the range defined by PID output range .
Please help to resolve this thing .
Attachment :- Output by running Vi & Vi also attahced .
Message 1 of 9
(3,998 Views)
Accepted by Nitin_110051
Hi Nitin,
so you limit the PID output range to a very small range - and then you wonder, why the PID control doesn't go outside of that small working range???
Btw. Why do you set the output to [1700, 1900] when you want to have a duty cycle as output value? What kind of duty cycle uses values like "1800"?
Message 2 of 9
(3,992 Views)
Good morning Gerd,
Even if i change the output range to 0 to 6000 , then i am getting the graph in which pulse is coming 0 to 6000 .
Practically it should maintain speed to setpoint, but i observe its behaving with ouptut range only .
Duty cycle :- this 1800 or whatever values in terms of 100 are the Rpm for the motor and i am coverting into duty cycle by dividing with the factor 6000.
Thanks & regards
Nitin
Message 3 of 9
(3,988 Views)
Hi Nitin,
can you attach your VI in LV2011?
Message 4 of 9
(3,982 Views)
Hi Gerd,
Please refer the attachment in 2011 version .
Thanks & regards
Nitin
Message 5 of 9
(3,936 Views)
Hi Nitin,
thanks for conversion.
On your VI:
- Why are you using so many local variables, causing race conditions?
- Why are there controls and indicators with exactly the same name ("frequency")?
- Why is "Output PID" set as control, when it just displays a value like an indicator?
- Why are you reading "N samples" from your frequency input, but using just one sample for the PID?
- Why are you manipulating the measurement value with an Abs() function?
- Why are you providing a dt=0.0001 to the PID function, when you use a WaitForMultiple set to multiples of 180ms?
There is so much wrong with your VI! Please correct all other problems before you even attempt to integrate a PID control…
From an UX point of view: Why do you use gauges as input controls?
Message 6 of 9
(3,923 Views)
HI Gerd
Thanks for information .
I tried with your observations , its working now . Some problems are still there like if i change the parameters(Kp=1.0,Ki=0.001,Kd=0.000 to Kp=2,Ki=0.001,Kd=0.001) its osciallting to much in the output range . and also if i hold the motor with hands softly  it is gaining speed and not coming back while holding the motor, once i realeased motor it is coming back .
Awnser's
On your VI:
- Why are you using so many local variables, causing race conditions? I  didn't know that variables can create race condition , can you suggest me some document regarding this ?
- Why are there controls and indicators with exactly the same name ("frequency")? :- Changed Now
- Why is "Output PID" set as control, when it just displays a value like an indicator? :-  Changed Now
- Why are you reading "N samples" from your frequency input, but using just one sample for the PID?  if i am using single samples  it is not working at all .
- Why are you manipulating the measurement value with an Abs() function? Changed Now
- Why are you providing a dt=0.0001 to the PID function, when you use a WaitForMultiple set to multiples of 180ms? Removed Now
There is so much wrong with your VI! Please correct all other problems before you even attempt to integrate a PID control…  Corrected
From an UX point of view: Why do you use gauges as input controls?I used gauges just for representation .
Attachment :- New VI
Message 7 of 9
(3,888 Views)
Hi Nitin,
The LabVIEW help explains the term "race condition"… (Googling for "labview help race condition" gives a lot of documentation!)
Now there are controls without a label: this is no good idea either…
 Now there is no timing at all in the loop - and you still provide the PID a wrong timing of 1e-4…
You still use gauges for inputs…
Do you know how to get estimates for PID parameters? Have you heard about Ziegler-Nichols? Wikipedia explains this with a lot of details!
Message 8 of 9
(3,875 Views)
Thanks Gerd
Now its working , But stil i am not able to set derivative .
Message 9 of 9
(3,855 Views)
