06-08-2010 10:18 AM
Hi I am Avi, I need the help in solving one problem in wave analysis. please help me in that....
We are doing project in post processing. ie, analysing the waveform. we have done that, but it is taking the average of the peak value and showing wrong peak value.
06-08-2010 11:49 AM
Avi,
Please give more specific information.
What kind of waveform do you have? What is the purpose of the analysis? How are you defining and detecting peaks? How are you averaging the peaks?
What is wrong with the value you are getting and why do you think it is wrong?
Please post the VI you have so far with some typical data saved as default. Also please indicate what you think the correct results should be.
Lynn
06-08-2010 11:59 AM
We have ASCII file and we have to browse that file and that file contains some junk data in that, we need to draw graphs between first column and 8th column and one more graph with first column and 9th column. The graph will not be in uniform so we need to take the average of all the un uniform points and should keep the peak value constant. I am attaching both ASCII file and VI which i have don till now among that post processing is the main one. please ask me, if u need any more information.
06-09-2010 03:32 PM
Hi Avi,
The zip files you posted seem to be empty or corrupt. Could you try reposting them along with some screen shots that describe what you are trying to do and the undesired behavior you are observing?
Thanks!
