resetting the PXI-1000B
I'm getting this error message, I've never turned the thing off before.  Does anyone know what this means?
Possible reason(s):
Driver Status:  (Hex 0xBFFA4ABB)
DAQmx Error -200324 occurred:
Device not available in NI-DAQmx. It is possible that the device is being used by Traditional NI-DAQ or that the device is being reset.
After using a device in Traditional NI-DAQ, you must reset the device before using it in NI-DAQmx. For SCXI devices, you must reset the communicator DAQ device. Call the Traditional NI-DAQ Device Reset VI or the Init_DA_Brds function. To reset all devices in Traditional NI-DAQ, right-click the Traditional NI-DAQ Devices folder in MAX and select Reset Driver for Traditional NI-DAQ. If you are resetting the device, wait for the reset to complete.
Status Code: -200324
(2,815 Views)
Accepted by topic author bbentelin
Nevermind I solved it.
(2,806 Views)
If you are going to mark your follow up message as solved, then please post in there what the solution was.  This helps people in the future who might find your post when they are searching for the answer to the same problem.
(2,797 Views)
Resetting the computer was all that was needed.  After turning the chasis on and off the active lights on the cards did not come back on.  But rebooting the computer and starting up labview again fixed the problem.
(2,795 Views)
