Need help with Signal Processing
I have four signal outputs, I did cross correlation of two signals, running average of it, and normalized the signal. But I was not able to see any peak in my cross-correlation waveform chart. I am new to labview and I would appreciated if someone could check my code. See if there's anything wrong that I did. Thank you very much in advance.
Message 1 of 1
(2,633 Views)
