signalexpress to labview
Dear all!
I'm using device USB-6009 in order to adquire data from a physical channel. I'm using the first attached vi to do this. The problem is that although i set the number of samples to 1000 and the adquisition rate to 1000, I'm not saving 1000 samples in each iteration. I have tried to do the same example with SignalExpress, setting the number of samples to 1K and the rate to 1K and after this, I've directly generated the labview code from SIgnalExpress (second attached vi.) with the tools-generate code->LabVIEW diagram option. Doing it this way, I get 1000 samples every while loop iteration.
Why differ the results?
I would really appreciate that somebody could help me,
Miren
(2,415 Views)
(2,387 Views)
