Need help with VI for a DIO 6509 card.
I need to create ONE VI to control different lines on the DIO 6509 card.  I want to be able to input the VI with the port/line i want to control and then also input it with the state, 0 or 1.  How can i do this with / or without the Assistant.   It seems like with the assistant, i have to know the state of every line on the port when i set it.  But sometimes i want to just set one particular line on the port with no regard to what the other lines are set to currently.
Thanks for any help,
Jason
(3,118 Views)
It can be done, just use the physical channels a build your tasks on the fly.  Your application sounds like a debug interface, so for an example you can setup your interface to read an Entire port or the entire card or whatever you wish, then choose to write a port out or line out.  All of this is possible through the DAQ MX VIs.  How many of these cards do you have in a single system?  What version of DaqMX do you have?  What version of LabVIEW?  Can you be a little more specific in what you want this application to do?
Paul
(3,094 Views)
I have one PXI-6509
I really only need to control 32 of the lines.  So right now i have a case structure with 32 different cases.  Each case has its own DAQ Assistant configured to a particular line.  So depending on the number you input, you get that port/line set on or off....  This works, but its very inefficient...  Its a small simple VI that is now over 3 megs in size (because of the 32 daq assistants).     I wasn't sure exactly how to use the lower level VI's to control the DIO line.  One thing in particular is that i dont know what my device number is...  The help says that it is the number i speciified during the config, but i dont see how to specify that.
Jason
(3,090 Views)
You can dynamically create the channel that you wire to DAQmx Create Channel. The syntax is Dev1/port0/line1 or Dev1/port2/line3. The channel name can be a string so based on a numeric control, you can create the correct one for a single channel. Then, your DAQmx Write should be set to Digital Bool 1Line 1Point. The data input for this is a single Boolean. You should be able to modify Write Dig Chan by changing the line input, the DAQmx Write, and the data from an array to a single Boolean.
(3,084 Views)
That would be for traditional DAQ.  You should be using DaqMX.  What verison of LabVIEW and NI-DAQ are you using?   I agree, this should be very small and efficient.
Paul
(3,082 Views)
