Need help with my project
too much wire and shift register, I am Confused, can you help me a little bit for the coding ?
Message 11 of 34
(1,985 Views)
You are right, too many shift registers and wires in your code.  You can move the indicator terminals inside of the event case.  That will make things a lot simpler.  It also helps if you properly label controls and wires.
GCentral
Message 12 of 34
(1,979 Views)
appreciate
Message 13 of 34
(1,968 Views)
can you plz show me the what is inside the "false " state, and btw why my stop can not wire to the "envent structure" ?labveiw questionE3.PNG
Message 14 of 34
(1,958 Views)
The other image is a snippet.  You can drag and drop it to your desktop, then drag it into your block diagram and have all the code.
That wire needs a source.  In the Stop event, put a true constant there and wire it out to the conditional terminal.
Message 15 of 34
(1,956 Views)
magic, amazing
Message 16 of 34
(1,952 Views)
Hi Knight of NI, I still have some problems, sorry to bother you again.
The problem is why my vi can only output in array 2(in the loop) while the vi running. If I want to output in array 1(out of the loop), I need to click the stop button every time.
Another problem is the reset button, I want a reset all the value to zero when I press this button, however it did not work.
The last problem is when I run the vi, when the first time I press the “toggle” ,in the “Frequency” and “break” indicator, there always some random number come out unless I press three times to finish a cycle the number will remain normal.
Message 17 of 34
(1,930 Views)
You need a different event case for each button you have.  You should have a Reset:Value Change and a Stop:Value Change events.  Do whatever you need to inside of those cases.
GCentral
Message 18 of 34
(1,914 Views)
however, I can't put two event structure in one loop.
Message 19 of 34
(1,880 Views)
Who said anything about having multiple Event Structures?  You want a different event CASE.  Right-click on the Event Structure and choose "Add Event Case".
GCentral
Message 20 of 34
(1,875 Views)
