Need help with removing trailing zeros
Hello.
I need help with replacing zeros in the string.
I have a string that is the output of the network packet. There are some trailing zeros in the packet.
I cannot see them in normal view, but the size of the string tells me that it is bigger then it looks.
When I switch to hex view, you can see zeros.
I tried to use search/replace function and use to find 0 and replace with empty string constant. But, fro some reason it was not removing zeros.
I need to stop string after *69.
(5,347 Views)
Hello.
(5,348 Views)
Accepted by Rus_K
Show your code.  You don't want to search and replace zeroes.  Those 00 in hex view show they are null characters.  (non-printable byte with value of zero).  You need to search and replace on that character.  (replace string should look like 00 when it is set to show hex code.
(5,340 Views)
Accepted by Rus_K
An alternative to the Search And Replace String here would be Match Pattern.
(5,305 Views)
Thank you. THis is what I wanted,
(5,289 Views)
Thank you
(5,288 Views)
LOL never occured to me to check that it was already answered.  I have nothing new to contribute.  😉
Bill
CLD
(Mid-Level minion.)
(5,280 Views)
