Need help with this VI
Hi student,
you should resolve the Front Panel errors!
The error is pretty clear: you created arrays but you did not define their datatype ("no elements and is undefined"). Define them!
Message 11 of 27
(2,172 Views)
I put numeric indicators in each of those arrays, but im getting weird errors now.
Message 12 of 27
(2,169 Views)
okay so i did that but now i have like invisible numbers but somehow max and min numbers are being picked up?
Message 13 of 27
(2,164 Views)
I see what happened. There is controls in the array I put in as the input to the bundle. I change them to indicators but I get errors.
Message 14 of 27
(2,157 Views)
Accepted by student11
where do you actually write data into those arrays? Right now you calculate MinMax from your generated data, but you throw the data away.
You need to write your random data into the array in the cluster. (THINK DATAFLOW!)
Message 15 of 27
(2,153 Views)
I got it. I cleaned it up and put the data flowing to the array as indicator and making that data go in to the bundle again which goes to the output cluster.
Thank you so much.
This class is a pain for me because I am spending most of my time in a 2 credit hour class, when I should be concentrating on my engineering classes (I'm a junior, done with general classes). I am a civil engineering major and lab view is not required, but I don't mind learning it as long as it is taught well. I am very angry at the fact that this class is unorganized and it is a pain for me.
We also have a project with the lego ev3 and we have to program it through labview. They did not teach us jack and expect us to go through hours of tutorials online to learn how to do it.
Is there a good solution to doing this rather than spending hours on this. I need to find a better solution to this. Any help is appreciated. If anyone knows a similar class doing this same stuff that posts their lectures online, I will appreciate that.
Message 16 of 27
(2,143 Views)
How did you attach the array in output cluster?
i am studying this...but when i did that, cluster changed indicator to control...
if you don't mind, can i get the file?
Message 17 of 27
(2,092 Views)
"kim123" Are you a petroleum engineering major, if so there's a good chance I know who you are.
I think this picture will solve the problem.  Make sure you know how to turn things into indicators, etc. I suggest creating the output cluster in the block diagram, by right clicking on the bundle and making a cluster constant. 66.png
Message 18 of 27
(2,064 Views)
lmao is this for Engineering 11? I feel ya buddy, the class sucks
Message 19 of 27
(2,063 Views)
Aggravating stereotype I feel is circulating the industry these days is that because LabVIEW is technically "VISUAL" that it's obviously much easier to program in.  I worked with a couple techs who were under this impression and spent many an hour going through the book and doing exercises and not a drop of it sticking.  The mantra of..."I can put a 2 here and a 5 here and put this addition symbol here and get a 7 when I push the run button....yep programming is easy" is beginning to annoy me.  Sorry you have to deal with that in a class.  Civils really shouldn't be bothering themselves with LabVIEW unless you took a basic programming class at somepoint in your life....and understood it.  DailyDose of ranting right there.
Message 20 of 27
(2,060 Views)
