Need information on USB frame grabber Labview compatible (planning to buy)
Hello all,
                  I am looking USB based frame grabbers which are compatible with LabVIEW only.  I need atleast 50 frames/sec acquisition rate. I am using PULNIX P2013P analog or monochrome CCIR camera with LabVIEW 8.2 version. Please suggest me any of such frame grabbers even third party products if they are available and also only compatible with LabVIEW.
regards
visu
(4,458 Views)
Here is the link that will answer your question. If you have any more, post back.
What Cameras are Supported by the NI-IMAQ for USB Cameras Driver?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(4,457 Views)
Hi
       I was nt asking for USB cameras information.......i was asking about USB based frame grabber cards.......
(4,433 Views)
There are no USB frame grabber cards provided by NI. The only form factors that are supported for frame grabbers are PCI, PCI-e and the PXI platform. If you are interested in using USB cameras, then all you need is NI-IMAQ for USB driver (the driver is not officially supported by NI) and a USB camera that is supported by the driver.
Message Edited by Adnan Z on 03-08-2009 07:42 AM
Adnan Zafar
(4,423 Views)
