multiple graph with checkbox
Hey guys,
                I'm trying to do a waveform graph with a checkbox  when it is checked the graph appears else it disappears. As you can see for one checkbox it's working properly, but when a put two checkboxes both graphs should appear in the waveform graph. I put the bunddle function, and its exit i'm linking to the waveform, but then an error appears. Does someone know anyway of putting two or more graphs together in a waveform graph, enabling them with checkboxes?
Message 1 of 11
(6,067 Views)
hi danilorj
        look at the attached vi.
Balaji(CLAD)
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 2 of 11
(6,043 Views)
I forget some changes,find the new attachment.
Balaji(CLAD)
Balaji PK (CLA)
Message 3 of 11
(6,033 Views)
Balaji PK (CLA)
Message 4 of 11
(6,032 Views)
Hai,
Look the attached vi which gives a comprehensive solution to deal with such tasks.  The vi uses the graph property nodes to make the plots visible/invisible and also manipulates the plot legend to reflect the changes in plots.
Feel free to post for any queries.
With regards,
JK
(Certified LabVIEW Developer)
Give Kudos for Good Answers, and Mark it a solution if your problem is solved.
Message 5 of 11
(6,028 Views)
Jk1,
        when the two checkboxes are unchecked your VI still calculates the interation.
Message 6 of 11
(6,011 Views)
Hai,
its a petty problem 🙂 just initialize the graph with two plots of zeros.
When you open the vi for the first time there are no plots in the graph and hence the initializing for loop returns error.  Just initilize the graph with two plots that will solve the problem.  See the modified vi attached...
With regards,
JK
Message 7 of 11
(6,007 Views)
JK1,
        could you explain to me why you used the xor function, and why it is linked to a Search 1D Array Function? I just can't understand the reasoning you used.
Message 8 of 11
(5,994 Views)
Hai,
The xor function is to detect which check box(s) have changed their state either from T to F or F to T. Xor function returns true for those elements that has changed its states..so the output of XOR with TRUE elements are those that have changed the states.  Search for the TRUE element with search 1D function and index that element from the array of check box values.  The index of the  checkbox that has changed is equivalent to the plot number and that plot needs to be visible or invisible.
Hope it helps.
With regards,
JK
Message 9 of 11
(5,975 Views)
Jk1,
          take a look at this Vi I did before. It's working the same way, except for some differents on the legend.
Message 10 of 11
(5,958 Views)
