Need long delay for buffered CO task
I want to create a buffered CO task, when triggered, delay 5 min before output pulse.  Is this possible?
PXIe-6341, Win7, LabVIEW 2013.
The channel property: initial delay doesn't work for buffered CO task.
The trigger property: start.delay not supported for the device.
George Zou
(3,365 Views)
Don't want to use event structure or software timing.
TIA
George Zou
(3,350 Views)
Any suggestions ?
George Zou
(3,312 Views)
Hey, George
I do have a suggestion for you. Here's some code that will delay a set number of pulses of an input signal. If you input a 1kHz signal, then waiting 300,000 ticks would correspond to 5 minutes. You may have to use another counter to generate a pulse train signal that acts as the 1 kHz input, but this code is how you can do they delay. After the 300,000 ticks are counted, a pulse of a specified width is outputted by the counter which you could use as a start trigger for another task.
Ryan P.
CLA
(3,297 Views)
Thanks for reply.
How do you do that ?  I don't see a start event for CO.
George Zou
(3,278 Views)
Hey George,
Do you mean how do you use the pulse that this code generates as a start trigger for another task? If so, you would use the DAQmx Export Signal VI which would allow you to export the "Counter Output Event" of this task to a PFI Line of your choice, which could then be used as the source for the trigger of another task.
Ryan
Ryan P.
CLA
(3,243 Views)
