Need more precise output
Precise response needed
I am adding some value
148.1  1111 1111 1111
129     1011 1101 1001
Please help me to solve is issue
 Thanks in advance
with regards
DK
(3,018 Views)
So an output from the vco is a 12-bit representation of the frequency that it is generating? There is probibly no way to increase the precision of that output.
You could however measure the voltage you are using to control the vco (to whatever precision you desire) and relate that to frequency. Where is that voltage coming from? Is it also being generated by the computer?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,013 Views)
I am using DAQ card to generate12 bit combination,for  each bit combination the VCO produces a voltage.With the program I am trying to produce the bit combination corresponding to the number(frequency) I am putting to the program.
 The DAQ is comnected to a DtoA then to VCO
I am getting the response exactly the same as number I am putting to program but not for all
(3,006 Views)
Duplicate Post:http://forums.ni.com/t5/Digital-I-O/2-digit-decimal-to-12-bit-binary/m-p/2584021
Duplicate Post:http://forums.ni.com/t5/Digital-I-O/Precise-response-needed/m-p/2586339
Please keep it all in a single thread.
(2,994 Views)
