Need "time" 1D array from DAQ assistant in DAQmx
Hi Magea,
so you create a scalar mean value from your Y array?
Then you should create a scalar X (aka "Time") value too - and then you plot Y vs X on a XY graph…
I tried to build another waveform from it, or concatenate it ... No way to solve that issue ...
Mind to attach your VI?
Message 11 of 15
(903 Views)
Here is a simplified version of my VI !
I obtain the mean that way, but if there is another way which makes more convenient my issue, I will look forward it .
What you say make sense !
But I really lack of basics knowledge about Labview and so I get confused between scalar, array and so ... I do not really know how to programm it ...
Message 12 of 15
(897 Views)
Hi Magea,
NI offers a lot of FREE online resources to learn LabVIEW…
Just an idea to calc both the mean of the Y values and the timestamps:
Recommandation:
Stay away from ExpressVIs (like DAQAssistent), it will simplify your VIs in the long run!
Message 13 of 15
(889 Views)
Thank you very much for your kind answer.
I ll try what you propose, and then try to plot it !
Message 14 of 15
(884 Views)
I feel very bad but I can not achieve to plot it ...
I did what you suggested and I udnerstand it.
But I can not find a way to plot the time stamps "updated" by dt VS mean.
Either I bundle these entries to a XY graph, or try to change time stamps to regular data, or whatever, I miss how to conclude this ...
Should I rebuild a waveform after those steps ?
Message 15 of 15
(868 Views)
