09-25-2017 08:54 PM
I made a VI to record some sensor data in my experiment and i am trying to acquire 512 data points in a period of 1sec but when i am trying to write the data to excel file in labview. it's recording 512 data points in less than 1 sec. it's not taking complete second. if i do a simple VI with only one sensor directly and writing it to the file then it's recording 512 data points in a time of 1sec.
I am using cDAQ9172 and NI9237 and NI9205 modules
Note: attaching latest version VI and compatible version VI
Thank you in advance
09-25-2017
09:53 PM
- last edited on
09-16-2025
02:43 PM
by
Content Cleaner
How do you know it is less than a second? How long does it take?
According to the data sheet for the NI-9237, the minimum data rate is 1.613 kS/sec. Much faster than 512 Hz.
https://www.ni.com/docs/en-US/bundle/ni-9237-specs/page/specs.html page 9.
09-25-2017 10:28 PM
How exact do you need that 512Hz? With a minimum sample rate of 1613S/s, you could average 3 or 4 samples at a to effectively reduce your sample rate to 537.7Hz or 403.25Hz respectively.
09-25-2017 10:42 PM - edited 09-25-2017 10:43 PM
It's not mandatory for me to take 512 data points. I am just confused with number of samples to read and sample rate. I just wanted to use both as same number in order for simpler calculations. If 9237 is 1.613ks/s what about 9205 ?
09-25-2017
10:47 PM
- last edited on
09-16-2025
02:43 PM
by
Content Cleaner
09-25-2017 10:57 PM
I am sorry i am new to LabVIEW and I am trying to learn step by step. So the frequency of 9205 is 250ks/s and 9237 is 1.613ks/s so considering both can I use 2048 in samples to read and 2048 in sample rate. Will that solve my issue ?
09-26-2017 06:37 AM
Hello guys i figured out the issue because i am using 9205 and 9237 modules for different sensors. i am facing that timing mismatch. Can any one guide me if i can implement them separately using 2 daqmx ?
09-26-2017
07:11 AM
- last edited on
09-16-2025
02:43 PM
by
Content Cleaner
Apparently not with that chassis.
You really need to learn to read manuals and specifications. cDAQ-9172 Specifications (page 20).
09-26-2017 07:32 AM
Yes I read the manual after replying to the post ☹️
09-26-2017 07:49 AM
Reminds me of the old response: "RTFM" (Read the Fine Manual)
