Need some Help Urgent!!!
I made a VI to record some sensor data in my experiment and i am trying to acquire 512 data points in a period of 1sec but when i am trying to write the data to excel file in labview. it's recording 512 data points in less than 1 sec. it's not taking complete second. if i do a simple VI with only one sensor directly and writing it to the file then it's recording 512 data points in a time of 1sec.
I am using cDAQ9172 and NI9237 and NI9205 modules
Note: attaching latest version VI and compatible version VI
Thank you in advance
Message 1 of 14
(4,407 Views)
How do you know it is less than a second?  How long does it take?
According to the data sheet for the NI-9237, the minimum data rate is 1.613 kS/sec.  Much faster than 512 Hz.
https://www.ni.com/docs/en-US/bundle/ni-9237-specs/page/specs.html page 9.
Message 2 of 14
(4,384 Views)
How exact do you need that 512Hz?  With a minimum sample rate of 1613S/s, you could average 3 or 4 samples at a to effectively reduce your sample rate to 537.7Hz or 403.25Hz respectively.
Message 3 of 14
(4,369 Views)
It's not mandatory for me to take 512 data points. I am just confused with number of samples to read and sample rate. I just wanted to use both as same number in order for simpler calculations. If 9237 is 1.613ks/s what about 9205 ?
Message 4 of 14
(4,364 Views)
Message 5 of 14
(4,358 Views)
I am sorry i am new to LabVIEW and I am trying to learn step by step. So the frequency of 9205 is 250ks/s and 9237 is 1.613ks/s so considering both can I use 2048 in samples to read and 2048 in sample rate. Will that solve my issue ?
Message 6 of 14
(4,354 Views)
Hello guys i figured out the issue because i am using 9205 and 9237 modules for different sensors. i am facing that timing mismatch. Can any one guide me if i can implement them separately using 2 daqmx ?
Message 7 of 14
(4,304 Views)
Apparently not with that chassis.
You really need to learn to read manuals and specifications. cDAQ-9172 Specifications (page 20).
Message 8 of 14
(4,295 Views)
Yes I read the manual after replying to the post ☹️
Message 9 of 14
(4,289 Views)
Reminds me of the old response:  "RTFM"  (Read the Fine Manual)
Message 10 of 14
(4,280 Views)
