Need someone with Labview 7.0 to save VI in 6.1
I need some help. I have a VI that was written in Labview 7.1, but our research grouip only has a license for 6.1. It's a fairly simple VI for controlling a piezo driven microscope stage. I manged to find someone else at the uni with Labview 7.1 to save it in version 7.0. Now I need someone to save it in version 6.1 for me. If anyone could help me out, it'd be greatly appreciated (and would save me a more than a few hours trying to write the VI myself)
Kind Regards,
Sam
Message 1 of 8
(3,138 Views)
Its seems you forgot to attach the code.
Please post the code so that somebody will save it for you.
Mathan
Message 2 of 8
(3,131 Views)
Thanks, I missed the attachment button when I was making the first post. I've attached both the original VI and the one saved in 7.0
-Sam
Message Edited by Sam Wallace on 05-18-2008 11:44 PM
Message 3 of 8
(3,122 Views)
Hi Sam,
i don´t think so. Smiley Happy I recommend to write it new. See the attached pictures as a suggestion. You don´t need local variables.
Mike
Message Edited by MikeS81 on 05-19-2008 08:07 AM
Message 4 of 8
(3,111 Views)
... and here the last case.
Mike
Message 5 of 8
(3,109 Views)
Hi Sam,
I would tend to agree with Mike that your best bet is probably to rebuild this VI.  Having said that, I was able to save it in 6.1 but I can't promise you that it will work correctly.  The way that LabVIEW handles variables has changed a great deal between 6.1 and 7.1 but the run arrow is not broken so give it a try and let me know if it works the way you expect it to.  Thanks and have a great day!
Stephen S.
1 Test is worth 1000 expert opinions
Message 6 of 8
(3,047 Views)
Thank you for your help Stephen, the conversion worked without any issues. However, I'm taking your advice and rebuilding it from scratch anyway, I want more control over the way it runs, and learning how LabVIEW works is more beneficial in the long run.
I apologise for the late reply, I've been somewhat caught up with teaching and other commitments I haven't had a chance to test any of this out until today.
-Sam
Message 7 of 8
(2,976 Views)
No problem Sam...I'm glad I could help.
Stephen S.
Message 8 of 8
(2,963 Views)
