Need the following .vi9(s)
My LV 6.1 machine with a full compliment of add-ons fails to find those VIs when searching.
I vote those are all custom VI or they were loaded as part of a some third party add-on.
Ben
Message 21 of 73
(1,757 Views)
I can assure they are not custom, they must be included in a toolkit
LabVIEW Intermediate I level!
Message 22 of 73
(1,750 Views)
Bebeto wrote:
First of all, this is the message I get when loading the VI:
An error ocurred loading VI"binRead.vi".
LabVIEW load error code 10: VI version (5.1.1) is to old to convert to the current LabVIEW version (8.6.1)
Now this is the path I get:
Loading:
C:\Documents and Settings\montoye\Desktop\HAWK GUIs\Strip Chart Source\HawkStripChart.vi\binRead.vi
 Searching:
I have never seen a spec like that.
A VI inside a VI?
If my coffee was fully functional, what would that tell me?
Ben
Message 23 of 73
(1,743 Views)
At this point I am thoroughly confused. I thought we were dealing with LabVIEW 6i VIs, now it seems we're trying to load LabVIEW 5.1 VIs in 8.6, and we're also apparently dealing with VIs inside of VIs. Smiley Surprised
Message 24 of 73
(1,738 Views)
well the LabVIEW version used was 6i, still the files can be from a previous version, and yes they are VIs inside the general VI
Message 25 of 73
(1,729 Views)
Just to rule it out I tried saving a VI into a llb and then from Windows. renamed the llb to just .VI and a caller was still able to find the sub VI inside the VI!
So try browsing into that "hawk" file to see if THE CUSTOM Vis are in there.
Ben
Message 26 of 73
(1,747 Views)
It's Colonel Mustard in the Study with the Candlestick.  😉
Even if it was from a toolkit, who would put something like that on their desktop??? 😮
I think you'd better find out who this "montoye" user is and see if you can find the folder.
Bill
Edit:
Even if you're using the same computer, if you're logged in as yourself (not "montoye") and you don't have admin rights to the computer, you won't be able to access that folder.  FYI
Message Edited by billko on 08-26-2009 09:39 AM
Bill
CLD
(Mid-Level minion.)
Message 27 of 73
(1,741 Views)
Ben
Image showing what I tried to describe above.
Ben
Message 28 of 73
(1,734 Views)
the VIs are not there, llike mentioned before I had the same problem with another Vi JtfaEngine.vi and it turned out to be inside an obsolete library. Then the people from NI converted the file for me to be readable in 8.6.1
Message 29 of 73
(1,729 Views)
That just doesn't make sense.  How can NI convert something that isn't there?  Do you mean the library had dependencies on VIs that no longer exist?  Anyway, the files that have problems are on somebody's dektop where they shouldn't belong.  That in itself tells me they are third party (custom) VIs, which is why everyone responding is having a difficult time supporting you.  NI doesn't install stuff to the desktop, BTW.  😉
Bill
Bill
CLD
(Mid-Level minion.)
Message 30 of 73
(1,722 Views)
