Need to change Function Pallette view
Hello!
 I have searched through options but did not found how to make Function Pallette to be able open SubVI's from cumstom location. I attached two pictures - one displays what I have and the second picture displays what I want.
 P.S.: I have LabView 7.1
Message Edited by ACiDuser on 05-23-2009 06:03 AM
(2,946 Views)
Select Tools»Advanced»Edit Palette Views to create or edit custom palette views.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(2,939 Views)
That will let them reorganize the palette. I think the user simply wants to have the category format with icons and text. You can do this from  Tools->Options. I don't remember if LabVIEW 7.1 provided the "View" menu to access this if you pinned the functions palette.
(2,908 Views)
Yes you are right. It seems that in LV 7.1 I can't create TEXT folders (links) on function palette.. It's very unconvenient cause I even can't create an empty row after last function row - only between two function rows. Or maybe I'm doing incorrect?
(2,896 Views)
Accepted by topic author ACiDuser
Oh, OK. Your pictures were somewhat misleading. I thought you just wanted to have the category names displayed. If you want to include a palette to your own folder you need to edit the palette as already mentioned. The LabVIEW Help describes how to do this. This is in the LabVIEW Environment -> Customizing Your Work Environment section.
(2,887 Views)
