Need to collect data every hr
I'm fairly new to labVIEW and need help with this particulare VI. It is setup to collect vibration data at noon and at midnight. What I need to be  able to do it alter it so I would be able to collect data every 1hr. And eventaully I want to collect data every 4 hrs. Any help would be appreciated.
(4,012 Views)
Accepted by jtc31909
I would set something up like this:
Use the Seconds To Date/Time to get a cluster of the time.  We are just needing the Hours, Minutes, and Seconds from the cluster.  For the hours, use the Quotient & Remainder to divide by whatever increment you want.  Add the remainder with the seconds and minutes.  If the sum is 0, then you can start your record.
(3,987 Views)
Thanks! I will give that a try.
(3,957 Views)
If you don't need to take samples at a particular time, but instead at a particular rate (e.g. every hour, every 4 hours, twice a day), consider putting a Timed Wait inside the sampling loop.  A loop with such a Wait doesn't take any CPU time while it is waiting, so you could (in principle) be doing other things (or, if running on batteries, you will probably lengthen the Recording Time ...).
(3,935 Views)
Thanks Bob
(3,924 Views)
Sorry my response is so late. I implemented the change, and set the increment to 1 to try and collect data every hr, but it doesn't seem to be working. Did I implement it incorrectly? Unfortunately I'm just not that experienced with Labview yet.
(3,826 Views)
Sorry, It does work. I just had my data file being saved to the wrong location. I was mistakenly thinking it was not recording.
Thanks!
(3,815 Views)
