I have string data that I need to convert to numbers so that I can graph it or perform calculations on it. The data (file attached) is in three columns (tab separated) and is in the format time/double/time (saved as a string with Write haracters to File.) When I try Read From Spreadsheet I get 0.0000 for column 1 and 2.0000 for column 3.
