Need to find In Port and Out Port vis.
Hi all.
I have some software running on old hardware that uses In Port.vi and Out Port.vi and I need to modernise it. I can't run it because it doesn't find these sub vis when loading. Is there anywhere I can find them? I don't have any very old versions on my machine any more. Thanks
(3,634 Views)
They don't exist anymore.  And if they did, I don't think they'd work because modern operating systems won't allow you to have the direct control of a hardware port that those VI's did.
(3,631 Views)
Thanks. I don't need them to work, I just need the vi to run so I can change some of the other sections of code and I can't get it to run if it doesn't load them.
(3,628 Views)
Hi ASH,
create two dummy VIs with the same name and connector pattern!
(In LV2011 and in LV2017 I still find that portaccess.llb in vi.lib\Platform…)
(3,626 Views)
Slap a diagram disable around them
(3,600 Views)
@GerdW wrote:
Hi ASH,
D'oh! why didn't I think of that! Thanks.
(3,595 Views)
I did try that but it still wouldn't run.
(3,592 Views)
