My main problem, put bluntly, is that I have basically no idea what I am doing...what I'd like to do is set up a system where I can take multiple thermocouple readings (I have the option 011 component, so I have 64 channels, which would imply that I can have up to 64 thermocouples).
Do I need one of those 150xA modules to read in thermocouples, or can I just use the built in straight-through modules? I found an Instrument Driver VI called Temp that was supposed to convert something into temperature units in some format, but I have no idea how to implement it.
The E1419A is in a E8408A VXI Mainframe, and it is connected to the computer via a E8491B IEEE-1394 card (the one that went in slot 0), which is connected to the FireWire card in the PC.
Do I use the VISA VIs, or do I use the Instrument Drivers? Either way, I need some help in understanding how to use them.
