Need versatile way to pass data to graph
I have a sub-vi that does some data analysis. I output the results through a type def. I want this type def to include the data needed to plot the results in a XY-graph.
My problem is that the data will sometimes contain only 1 data series and sometimes multiple ones. i.e. sometimes the output should be a cluster of two 1D-arrays, sometimes it should be an array of clusters. Is there a good way to achieve this?
vs
(3,864 Views)
Dulpicate Post,
please maintanin single thread
http://forums.ni.com/t5/Getting-Started-on-the-NI/Tips-for-Posting-Code/td-p/3250924
(3,859 Views)
You can try using for loop with indexing enabled so that you will come to know how many coulumns you have during run time and cluster them and then index out so that you will have array of clusters always.
uday
(3,851 Views)
Accepted by HenrikOlsson
You are on the right track.  Just need a little bit before the loop to transpose the array (to make the indexing work properly) and remove the X-axis data.
(3,838 Views)
