06-12-2011 01:20 AM
I am trying to open the attached llb for nerual network, but the version is too low to open, I am using 2010.
Is there any way to solve it.
In NN, I just found in the middle layer, the neurons seems not talk to each other in the model, this is not real in real brain, even adding more layer in the mid may not fit the real fact, also the neuron is communicate in double ways, but the model always transmit signal in one way. Is there any new model, thanks.
06-12-2011
02:44 AM
- last edited on
06-22-2026
01:49 PM
by
Content Cleaner
The VIs are in version 4, which is too early to open with LabVIEW 2010.
You also need LabVIEW 8.2 or earlier. (The version compatibility matrix can be found here [chart no longer available in this article].)
Alternatively, you can post it in the upconvert request thread and somebody will upgrade it for you.
I don't understand what you are trying to say in your last paragraph. Are you refering to something specific?
