.Net events not received after LV 2013.
In lieu of trying to ascertain what has changed between LV versions (which, even if we found out, would not be helpful is it will not change) it might be a good time for a work-around. Ultimately you will need to provide a lot more detail as the specifics matter (for example - code that demonstrates the problem). I assume you have progressed this also with NI support with same code, maybe it is a case of wait and see.
Looking into your IPC issue, I see that there will be a few things to work out regarding how far you will be able to take impersonation without requiring the host process to be elevated (https://msdn.microsoft.com/en-us/library/ms172351(v=vs.100).aspx). The best option would be for the server process to run under a service or similar account (rather than admin) to better enable access.
Message 11 of 11
(431 Views)
