Network Analyzer labview program
What you posted shows the 1-D array of frequencies being written first followed by the 2-D array of phase/mag data.  That is the opposite of what your latest .xls file showed.
Use Build array to concatenate your arrays together and use transpose where necessary.
Message 71 of 75
(2,151 Views)
I can't connect that last build array with transpose because the build array is making a 3D array
Message 72 of 75
(2,132 Views)
This is the output I'm getting and I don't quite understand it
Message 73 of 75
(2,126 Views)
You have to right-click on the Build Array and select "Concatenate Inputs". This is explained in the LabVIEW Help and is basic LabVIEW knowledge.
Message 74 of 75
(2,124 Views)
Can you look at my program and my output. On my output I don't know why it only displays the last set of points (2,2). It doesn't display (1,1) (1,2) (2,1).
Message 75 of 75
(2,095 Views)
